Hi there,
I wonder if anybody out there can help, I have this amplifier connected to a PC through HDMI and then through to a projector, works fine when I play say YouTube video, however if I connect to say Netflicks or SkyGO then the auto sync keeps searching for a HDMI Source, even though I have fixed the source to HDMI1 it just does not want to stay on that source for some reason?
I have ruled out all the kit bypassing the Sony Amplifier and everything works fine!!
Any help would be appreciated, Thanks Jason
Hi PositiveIT,
Welcome to the Community.
It might be best to contact Sony Support about this.
Thanks,
Pascale
Hi PositiveIT,
Thanks,
Pascale
Thank you Pascale, sure will give that a try!!!
