i have a bose lifestyle 25 system.
my tv is a KD 50SD8005.
How can i connect the 2 - so i can get surround sound through the bose speakers.
thanks
Hi David,
I'll look into this and will update the thread when I have an answer.
Best wishes,
Sean
Hi david12
Your TV supports connecting an external audio system via Digital Optical or HDMI ARC. Check if either options is supported by your Bose system and get the right cable.
Win_88
Thanks for that will give it a go
Thanks for your suggestions unfortunately the bose does not have either.
good day any suggestions as the bose does not have a HDMI ARC or an digital optical connector
