Hi in the manual on page 28 for my Sony STR-DA5300ES is says :
"HDMI IN6 is input which is considered sound quality"
What exactly does this mean ? Are the other 5 HDMI ports not exactly the same ?
It's Sony's shocking english translation
But seriously - it had bugged me for years as well but I eventually found the answer. Basically HDMI6 is routed internally to reduce the amount of interference to enhance audio quality so if you have a high quality audio source (eg SACD or DVD-A) that is one you should use.
Thanks for the reply.
so using a blu-ray player, should that go on HDMI6 or any ?
Not sure it matters to be honest - I stuck mine into HDMI1 of my 5300ES and it sounds great.
Great thanks for that "correct answer" goes to you
