sony soundbar system HTRT3 fan problem
profile.country.GB.title
Latgalietis7408
Explorer
Hello, i have problem with my HTRT3 subwoofer fan. Its very loud. Is there any hope that warranty service will fix that or that its how it works? If is than maybe i can put another fan, only there is diffent voltage. Orginal is 5v and 0.06A. I found one very qout with 0.12A. Can i replace with this? Or maybe i can just plug out fan. And yes i know i will loose warranty. Want your opinion. Thanks
1 REPLY 1
Sean_Mc
Moderator
Hi there,
It would be best to get in touch with the Sony support team for further assistance here.
Best wishes,
Sean Mc
