My DVD recorder is no longer picking up channels so I cannot record.This happened after the digital change over. The TV is digital and works fine, I just can't record programs. Help please ??
Ewen
Thank you so much, helps a great deal. I guess using the 2006 manual is not clever as it refers to a by-gone age. I will continue the slow journey forwards!
Very many thanks.
Any idea why the machine will record onto the hard disk, but says the new blank dvds cannot be recorded on?
Rooob you are right. My problem began a few months ago after the digital changes were made. I do have a set top BT box. My gripe is I used to be able to delete ads from recordings on the hard drive before dubbing to DVD. Now they do not give options for doing that or even to divide recordings into two or more parts. I will have to pop into Sony and see what is the modern equivalent. Why can't they let us old fogies keep our toys!
Unofrtunately @Vidbec there are no modern equivalent of those wonderful machine (at least not in Europe for Sony while they are producing still them for Japan) because probably most of the person find it enough the basic PVR options you may have on modern TVs. My RDRHXD870 is still working fine and hope will do till at least the next switch to DVBT2
