- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi everyone,
Just an update on the current EPG issue that seems to be affecting a significant amount of Sony & Pioneer DVD recorders.
Models potentially affected are:
RDR-HXD770/870/970/1070/790/890/995/1095
It appears that something has changed in the way that these devices are receiving EPG data. So we are already trying to understand what has happened and how this can be rectified, realising that a large number of people have been affected.
Latest Update 22/07/2013 15:41
Sony has been working with the broadcasters to try to work out why this issue has occurred and how to remedy it. With your help Sony has discovered that clearing down potentially corrupt broadcast data (EPG) stored within the machine will remedy this issue.
Whilst we continue to work with the broadcasters, and ahead of any final statement, we recommend the following steps to remedy this issue:
1/.
i). Turn off the DVD/HDD recorder at the mains (ie remove the plug from the wall)
ii). Wait 30 seconds
iii). Reconnect the power.
The set may now work correctly.
However, in certain cases it may be necessary to carry out a full factory reset as follows (please note this will return the product to its original out-of-box 'Easy Set Up' position so you will need to set-up the product as if it were new):
2/.
i). Make sure the DVD/HDD recorder is turned 'on'
ii). Remove any DVD disc from the machine and close the drawer.
iii). Press and hold the "Stop" button, then press and release the "on/standby" button, then release the "Stop" button (ON THE RECORDER, not the remote)
iv). The product is then turned 'off' and all settings are reset to factory default, with all potentially corrupt 'tuning' and 'EPG' data removed.
v). The DVD/HDD recorder will now need to be re-tuned and set up following the step-by-step on screen instructions - Note: Choose "Digital Guide" rather than "Guide Plus" at the relevant stage of the set-up (Guide Plus is no longer broadcast).
In the unlikely event that you still experience difficulties, please contact the Sony consumer helpline on 0844 8466 555 or for more info visit: http://www.sony.co.uk/support/en/topics/RDR_HN
Many thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No problem
FWIW mine is still all OK, so maybe its a transmitter based glitch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@ Nico Henderijckx, Sony European Forum & Communities Manager.
Your message (no 2, around 22 or 23 July) said that 'future official updates from Sony will be posted in this thread'.
When (approximately) will there be a full statement by Sony (preferably agreed with Digital UK) on this thread explaining what the problem was?
RE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Mine is working perfectly using the Belmont transmitter, so I guess it is transmitter related (unless you know different) and has nothing to do with SONY
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just to let you all know Sony are aware that some of you are reporting your RDR are stuck in update mode again and the problem is being investigated..
If I get any information I will pass it on asap..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
my firmware is up to date on 1.70 and has been ok since a week last sunday until this lunchtime. there is deffo a fault on the epg and hopefully sony know who to ring up about it, unlike me as I dont have numbers for arqiva or digital_uk
I know sony are not responsible for the fault, but they have more influence then I do and maybe they will issue a firmware update to stop the crippling effect of these epg data failures ? who knows . my point was its better to let them know in case they can sort the fiasco out with the people responsible for it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello,
I have just spoken to sony support and they did not tell me they were looking into it. they gave me the factory reset instructions. (not sure the girl I spoke to understood what i was saying to her) so have had to retune to france again.my dvd is an hxd995 picking up winterhill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
the only way I can fix it is using FRANCE (or belgium) as my location, same as we did the other week. no problems on the epg or channels on my tv`s, just these sony recorders once more - so to me its the same fault - but I can only test winter hill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@sbrobbs wrote:
Hello,
The people I reported this to do not work in the call centre..:smileywink:
