Hi everyone,
Just an update on the current EPG issue that seems to be affecting a significant amount of Sony & Pioneer DVD recorders.
Models potentially affected are:
RDR-HXD770/870/970/1070/790/890/995/1095
It appears that something has changed in the way that these devices are receiving EPG data. So we are already trying to understand what has happened and how this can be rectified, realising that a large number of people have been affected.
Latest Update 22/07/2013 15:41
Sony has been working with the broadcasters to try to work out why this issue has occurred and how to remedy it. With your help Sony has discovered that clearing down potentially corrupt broadcast data (EPG) stored within the machine will remedy this issue.
Whilst we continue to work with the broadcasters, and ahead of any final statement, we recommend the following steps to remedy this issue:
1/.
i). Turn off the DVD/HDD recorder at the mains (ie remove the plug from the wall)
ii). Wait 30 seconds
iii). Reconnect the power.
The set may now work correctly.
However, in certain cases it may be necessary to carry out a full factory reset as follows (please note this will return the product to its original out-of-box 'Easy Set Up' position so you will need to set-up the product as if it were new):
2/.
i). Make sure the DVD/HDD recorder is turned 'on'
ii). Remove any DVD disc from the machine and close the drawer.
iii). Press and hold the "Stop" button, then press and release the "on/standby" button, then release the "Stop" button (ON THE RECORDER, not the remote)
iv). The product is then turned 'off' and all settings are reset to factory default, with all potentially corrupt 'tuning' and 'EPG' data removed.
v). The DVD/HDD recorder will now need to be re-tuned and set up following the step-by-step on screen instructions - Note: Choose "Digital Guide" rather than "Guide Plus" at the relevant stage of the set-up (Guide Plus is no longer broadcast).
In the unlikely event that you still experience difficulties, please contact the Sony consumer helpline on 0844 8466 555 or for more info visit: http://www.sony.co.uk/support/en/topics/RDR_HN
Many thanks
No problem
FWIW mine is still all OK, so maybe its a transmitter based glitch
@ Nico Henderijckx, Sony European Forum & Communities Manager.
Your message (no 2, around 22 or 23 July) said that 'future official updates from Sony will be posted in this thread'.
When (approximately) will there be a full statement by Sony (preferably agreed with Digital UK) on this thread explaining what the problem was?
RE
Mine is working perfectly using the Belmont transmitter, so I guess it is transmitter related (unless you know different) and has nothing to do with SONY
Hello,
I have just spoken to sony support and they did not tell me they were looking into it. they gave me the factory reset instructions. (not sure the girl I spoke to understood what i was saying to her) so have had to retune to france again.my dvd is an hxd995 picking up winterhill
@sbrobbs wrote:
Hello,
The people I reported this to do not work in the call centre..:smileywink:
