Hi
I resently bought the Sony HT-XF9000 sound bar to accomany my sony TV. The idea is to wall mount the TV and recess the sound bar in to the wall (see example pic). I dont think the sound bar has upward facing speakers, but i wanted to check that by recessing the sound bar that it wont affect the sound quality.
The alternative will be to put it on a shelf, but im after the sleek moden look
Any advice would be greatly appreciate
Thanks
Hi there,
I'm looking into this for you and will update the thread when I have an answer for you.
Best wishes,
Sean Mc
Hi Smithy39,
I guess placing it too far inside might affect the surround sound of the soundbar.
Cheers,
Tenneen9000
