my
SONY HT-CT60 Sound Bar was working normally but now when i turning on it is not working. No lights come up. But with the same remote i can turn on the TV with TV button on the remote normally. Changed power cable and remote battery, still not working or the power light turning on. Please help.
Regards,
John
Hi John,
It might be best to get in touch with the the support team who will be able to advise on this further here.
Best wishes,
Sean Mc
Mine is having the same issue. Was working properly and then it suddenly stopped. The light comes up and i checked the optical wire and it’s very ok
