Hi i have a Sony BDV-E190 hooked up to a Playstation 4 via an optical cable
what are the best audio settings on both systems to get 3d sound on this setup ?
Thanks in advance
Lee
Optical supports 5.1 output - however its a mute point because I would send it via bitstream and let the E190 do the audio processing.
In regards to sound effects - im not a fan of them personally, simulated effects and all.
Sounds right.
A couple of links you might find useful:
http://www.soundandvision.com/content/pcm-vs-bitstream
http://www.avsforum.com/t/1320428/bitstream-or-pcm-ps3-or-receiver
HI there
Once you plug the optical cable from the PS4, and changed the audio settings to output via optical, there are very little settings. Sound is subjective too - meaning whats good for one, can be different to another. On the E190, you can experiment with "Sound Mode" and "Sound Effects"
well there is lots of different sound options on both
on the PS4
Audio Format (Priority)
there is LPCM which i know is only stereo through optical
Dolby Digital (bitstream)
DTS (Bitstream)
& on the BDV-E190
[Sound Effect]
You can set the system’s sound effects (SOUND MODE setting ) on/off.
For a 2-channel source, you can select [Dolby Pro Logic], [DTS Neo:6 Cinema], or [DTS Neo:6 Music] to simulate surround sound.
[Sound Mode On] : Enables the surround effectof the sound mode . The sampling frequency upper limit is set to 48 kHz.
[Dolby Pro Logic]: The system simulates surround sound from 2-channel sources and outputs sound from all the 5.1 channel speakers (Dolby Pro Logic decoding) .
[DTS Neo:6 Cinema]/[DTS Neo:6 Music]: The system simulates surround sound from 2-channel sources and produces 6.1 channel sound (DTS Neo:6 Cinema/DTS Neo:6 Music mode decoding) .
[Off]: The sound effects are disabled. You can hear sound as it is recorded.
So being a newbie to all these sound settings i'm not so sure what to use
well at the moment i got dolby digital set on the PS4
& on the BDVE190 sound effects set to off, so it plays the audio as it recieves it, i'm guessing.....
But i'm only guessing really
Sounds right.
Thanks for all the help
