as per title - my Sony BDP-S185 player will not play 'The Help' bluray disc.
The disc looks fine, no scratches or marks, I am using the latest firmware but the disc will not play. The disc reports correctly on the sony menu as Video disc 'The help' but when I try and play the player makes some noise as though reading, or trying to read from the disc and then the player goes into standby. Tried re-starting the player but again get disc spinning/reading noise and then the player again goes into standby.
Any ideas ?
Hi i'm having the same issue with "the help" from lovefilm. Is a fix out there yet? otherwise i will return my player within the next few days. This is just rediculus....
Hi all,
can anyone confirm if the firmware update version M07.R.6020 resolved the playback issue..:smileyconfused:
