Recently purchased this from Tesco. No issues with Blu Ray playback but can't stream Netflix movies wirelessly. Can logon on to the site, choose a movies and begin playback without any issues and then all of a sudden it will stop streaming and then try to reconnect, which basiclayy spoils the viewing.
At first I thought it was my intrenet but I can stream fine without any issues from any handheld devices connected with my network.
I've tried a factory reset and the latest firmware is installed. Even tried on a different network and still get the same issue.
Any clues?
Hi there
First thing to rule out in this case is the "wireless" issue. Try connecting the Bluray player to your router via a network cable and test it.
Have you tried it on a different internet connection - maybe a friends or someting similar. Past experience suggests its a localised ISP/Router/IP address issue.
thanks
