Has anyone managed to Power Up the Receiver using Songpal. Looks like I can only power it down using Songpal.
Thanks,
John
for anyone looking for a solution for this problem, the only way is to get your firmware downgraded. My Songpal now happily turns my Receiver ON on launch. An authorised Sony Service center was able to do this for me. OR hope that a future firmware will bring this functionality back
Hello there
I found this:
http://helpguide.sony.net/ha/strdn10686/v1/en/contents/TP0000638181.html
The Remote Start, I think is referring to the TV and Video Sideview App that Sony has.
Thanks for the information, Quinnicus. Some of the overseas model (US, Canada, etc) support Network standby, and the UK model did support it until the latest firmware, not anymore though. With Network Standby ON, you were able to turn the device ON using Songpal (the device turned itself ON when launching Songpal).
