Rear speakers for a sound bar
profile.country.GB.title
tiggiedapuss
New
Does anyone know if there are wireless speakers that can be connected to a Sony  XF-9000 sound bar ?
4 REPLIES 4
Pascale_F
Moderator
Hi tiggiedapuss,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Vanilla_
Contributor
Hi tiggiedapuss,
I've checked the possibility of this, and it seems that your soundbar doesn't support the connection with other wireless speakers. I've found this article from Sony listing the compatible models: https://www.sony.co.uk/electronics/support/articles/00151286
Vanilla_
tiggiedapuss
New
Thanks for that it’s a pity that I was not told that when I purchased it instead I was told the vertical S setting takes care of the sound coming from the rear which is a lie , I took the sound bar back albeit 2 months later and got it upgraded to a HT-ZF9 soundbar , and got the rear speakers that go with it , I couldn’t be happier even though it ended up costing double the price of the 9000 sound bar
tiggiedapuss
New
It’s ok  its been sorted
