Hi there
Try doing a factory reset on the RDR... It may clear any settings that has got "stuck" then try re-tuning it in again.
Cheers.
The only other thing that I can suggest is to ensure that you have the correct Country/Region set for the Guide+
Page 44 of the Manual : Here
If that doesnt work, maybe another forum member might have another idea.
