sq8bgq2
New
No bass with tv
Hi all,
I have got soundbar sony ht-s350, which was working fine with my old non smart TV and fire stick. Bass was amazing. Yesterday I connected the soundbar to my new 65 Sony lcd TV, kd65xh8196bu, and bass is almost unnoticeable. Does not matter if I connect it with arc hdmi or optical toslink. Help 😞
3 REPLIES 3
profile.country.DE.title
Peter_S.
Genius
It shouldn't make much difference if you connect via ARC or TOS Link.
Please try if setting the digital output of the TV to PCM improves the bass sound.
sq8bgq2
New
I did mean I have already tried to connect the soundbar using hdmi arc and toslink. Both do not really work. The bas us almost unnoticeable. If I connect the soundbar to the old TV with fire stick or i connect my mobile phone through Bluetooth the bass shakes my house. So the problem is between TV and soundbar. They are both Sony but do not like each other. I tried to find any sensible settings in tv, with no success. I found equaliser but is works only with internal speakers
profile.country.GB.title
Joe_Dohn
Specialist
Have you tried changing the Sound mode? There should be a separate Dolby mode that you can try.
