Hi
Just bought my second SRS-ZR5 og wanted to set up wireless surround with my HT-NT5 soundbar.
Everything works perfectly except for the almost non-excisting sound in the two SRS-ZR5s.
I have increased both the virtual distance to my listening position and the "gain" on the speakers but the sound is very low.
I believe I have tried everything to increase the sound in the back speakers but if you have an idea it is greately received.
Kindest regards Nikolaj
Hi I have the same problem and I tried MIchaels link on his answer but it didnt work so none the wiser! My problem is with a CT290 and two ZR5's, so far I have been really disappointed with the performance of the ZR5's. Have run out of ideas to try, particulary wanted the dialogue to be louder as the TV is in a large room and so we have to sit a reasonable distance away and can be hard to hear what they are saying on the tv, maybe its because the system is surround sound and doesnt send the dialogue to the ZR5's. Any suggestions?
