Hi all,
Sony HT-MT500 sound bar, S/W m39.r.0106
Sony KD-498309C 4K TV, build 3.885
Having problems with lip sync while watching any source from the sound bar, it starts ok then it loses sync ( may be five minutes to three hours on time ). If I change the sound field it syncs ok, till the next out of sync, repeat above.
Connected devices.
Digital aerial
Virgin Tivo cable box
Blue Ray player
Sat tuner
Thanks
John
I have just bought a HT-MT300 sound bar AND THERE IS AN AUDIO DELAY! The only audio input is optical (no HDMI). Have contacted Sony tech help and no solution yet after resetting everything twice (and loosing all my personal preferences on th tv). For Quinnicus to say there have been no other reports he should just have a look at the US community!
I have the same problem with HT-MT300 - seems to take longer for audio to get to sound bar compared to video. Seems to be no means of adjustment. Same problem when using sky and blue ray player via HDMI to TV (both Sony products). Does Sony have a solution or do we all have to exchange for BOSE?!
The Bose doesn't have variable delay. I think it's both the Sony bar and the Sony tv that are causing it. I have no problems with the Bose since installling it, great sound bar and worth every penny.
I have had a similar problem with the HT-MT300 soundbar, using a recently purchased Samsung TV.
I've fixed it by connecting the soundbar directly to our Virgin TV box using optical cable. The Virgin V6 box has an optical socket at the back which you can use.
Lip sync problem on my HT-MT500 started 2nd week in October, that was 3 weeks ago at time of writing. I purchased it from J Lewis back in February 2018, have tried all recomended procedures to put it right, but to no avail. Will return it to shop for refund.
