We have an KD55AG9 and have recently purchased a SONOS Arc. We’ve connected the SONOS Arc via the eArc port but cannot get the TV Speakers to act as the central console. Plus when the audio system is connected we cannot manually select to use the TV Speakers as it immediately defaults back to the Audio System despite amending the settings on tv to not default to the audio system. Has anyone got this working properly?
@andypodd2008 ha scritto:
As far as I know you have to have a proper AVR not a soundbar to use the tv as the central speaker. Does your Sonos soundbar have the possibility to wire an external center speaker ? I don't think so.
Hi andy,
Since you made sure to select the TV speakers as the default, then try to connect different sound device through the eARC port and double check if there are any changes.
Also, make sure to get your software up to do date from here: https://bit.ly/3da2oAK
Hopefully this will sort it out
-Piscie
Salut,
J’ai la même configuration que toi avec une SONS BEAM2 et une fois installée
j’ai les même soucis d’activation des hp tv.
As-tu trouver la solution ?
No solution unfortunately
Can anyone else help?
