I am sending via ChromeCast HiRes 96k/24bit audio streamed from Qobuz.
Does the ChromeCast integration on the HT-NT5 operate at HiRes (96k/24)
(BTW I tried connecting a hardare ChromeCast Audio - via optical tos link to the HT-NT5 optical (TV) input and it was silent with 96k signal, it would only play audio at the lower 44.1k sample rate)
Thank you
One problem,
It seems that GoogleCast isnt possible with surround speakers running.
So thats no good for 5.1 audio...
Unless I have that wrong?
I bought a Chromecast Audio which outputs 96k 24bit hi res signal
But it's not being accepted by the HT-NT5 optical input.
44.1k k Redbook audio plays but when is send hires music signal (96k 24bi) to the chromecast audio there is no sound
Can you help me troubleshoot please?
What hi res sample rates does the HT-NT5 accept?
And what inputs does it accept it on?
Does it accept Multichannel (5.1) audio via optical?
Does it accept Multichannel (5.1) audio via HDMI?
Please confirm / clarify the HT-NT5 HiRes connectivity options
Thank you.
And please confirm thr maximum sample rates
(does it work with 192k 24 bit signal or dsd for instance?
Hi there
Unfortunately I cannot answer your questions on this - I do not have this information.
At current I cannot send an escalation to Sony from this thread (as its not working!) - however I will pass on your questions to my contacts within Sony for assistance.
Here are some tests I did today
Equipment list
