Now that the A1 OLED TV and the UBXP800 UHD player are finally both available in the UK, all that I'm waiting for is the HT-ST 5000 Dolby Atmos sound bar, so that I can order a complete UHD system.
Does anyone know what is the likely HT-ST 5000 release date anywhere and /or in the UK?
Hi there
According to:
http://www.simplyelectricals.co.uk/sony-ht-st5000-712-hi-res-dolby-atmos-sound-bar
"This Sony Dolby Atmos Soundbar is available for pre-order, stock due mid June"
Unfortunately I do not have official information for you, but from previous experience with Simply Electricals - they have been pretty well bang on.
Hi there
According to:
