Hi , can i ( or will it automatic ) link the HT-S2000 with a SA-SW3 with out WiFi after set up with WiFi and Phone ?
Hi @50nWyToMe https://www.sony.co.uk/electronics/support/sound-bars-home-theater-systems-sound-bars-surround-speak...
Yes it´did work fine , first with " the App" , then with out WiFi too
