Hey there
So far so good, I guess 1 little issue to clear up.
Just curious if you have disconnected the optical cable. If not, remove it (as its no longer needed). That should clear that issue.
On the HT-CT260H, goto Audio Settings > TV Audio > and select "TV (HDMI)"
Page 25 of the manual
Thank you yet again! That was the setting that I had missed, it seems so obvious now.
I really appreciate your help getting this setup
Your welcome, not a problem
Have Fun
