As the title suggests, I can't get the drawer to open. The child lock isn't on. It makes a noise like it's thinking about opening and the display says 'opening', then it gives up and says 'closing'. Any ideas?
Problem solved. I just poked around the opening of the drawer, with a pin. It seemed to be physically stuck at one end and I heard it free-up as I poked. Tried again and it worked. I blame my 2-year old son, who stands on it to reach the buttons on the tv!
Try unplugging it from the mains power for 5 min or so, then power it up and try again.
If that doesnt work, press the 'open' button and push the drawer closed at the same time.
