Hi, I have the 50X90S TV and the HT-A3000 soundbar.
I thought the acoustic centre sync feature was compatible with both of these but I can’t seem to get them to work. I have connected them together with the included cable, but no luck.
Any ideas? Thanks
The PDF of the Italian Technical Data Sheet also talks about the possibility of using AV IN for S-Center Speaker, but the X90S Quick Setup Guide does not show the Connection in combination with AV IN...
X90S is not among the compatible TVs in fact:
How to use your TV's built-in speakers as a centre speaker
https://www.sony.co.uk/electronics/support/articles/00201071
Hi, are you sure where you connected the cable to the TV, to which input?
I connected it to the “AV in” input. It fit perfectly so I figured it was the right one. Am I wrong?
The support pages suggested the X90K was compatible and the X90S is just the 50 inch version of that, perhaps I was mistaken.
Oh, right. That is disappointing. Oh well.
I didn’t realise the X90S had differences from the X90K other than size.
Thanks for your help.
