Connecting KD-55XF8796 to an HT-SF150 sound bar
SOLVED
profile.country.GB.title
paul1stadd
Explorer
Hi, purchased a Bravia KD-55XF8796 a couple of weeks ago and got a sound bar (Sony HT-SF150) sound bar at Christmas and have spent the last two days trying to connect them - I’ve tried using an HDMI cable in the ARC port, tried using the audio cable and even tried using them both at the same time - the best I’ve had is a faint sound with the audio cable. The Tv acknowledges the sound bar but there’s nothing... please help!
1 ACCEPTED SOLUTION
Accepted Solutions
paul1stadd
Explorer
SORTED!!
It was the Digital audio out volume setting!
Action , menu - sound - advance setting - common - digital audio out (set to Max)
Thank you!
6 REPLIES 6
profile.country.DE.title
IamNic
Expert
Hello @paul1stadd,
did you ensure, that your HDMI-cable supports ARC?
If it does not, it won't work if you connect the TV and the soundbar together.
- Nic
paul1stadd
Explorer
Thanks - I'll try another HDMI cabl..!
paul1stadd
Explorer
Hi, tried a cable that says it’s ARC, there’s a tiny amount of sound at full volume but that’s it, anytyelse to try?
IamNic
Expert
Hello @paul1stadd,
did you try to adjust the settings on your TV to change the audio-signal-format it sends to the soundbar.
Maybe the default setting is not suited for your soundbar.
- Nic
paul1stadd
Explorer
SORTED!!
Thank you!
IamNic
Expert
Hello @paul1stadd,
glad you found the solution :yahoo:
I marked your last reply as such.
- Nic
