Hi
Is it possible to use different speaker set than the one provided in the home cinema Sony bdv-e370? I have an infinity Beta HCS home cinema sepakers set, which have 8 Ohm impedance. Can I connect those ones to the Sony bdv-e370 instead of the original ones?
Thanks in advance for the answer
