BluRay Player BDP-S5560
SOLVED
profile.country.GB.title
SLOWRAMBLER
New
Unit will not boot or expel Blu Ray disc
Audible clicking of tray mechanism
How do I reset ?
keith
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.DE.title
IamNic
Expert
Hello @SLOWRAMBLER,
disconnect the power cord, hold down the eject button on the device then reconnect the power.
You may need a second person to help you.
- Nic
2 REPLIES 2
IamNic
Expert
Hello @SLOWRAMBLER,
- Nic
SLOWRAMBLER
New
Thanks for taking the trouble to reply Nic
You were correct I had to look under the hood and use a screwdriver
None of the Sony remedies worked
Fixed it myself with help
