- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
hi
the home cinema 3d system as the model in the title doesn't seem to have anyway of adjusting how close you are to each speaker i.e how loud you want each speaker individually depending on your location in the room.my question is is this preset and no way of adjusting ?
thanks
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
I believe you can adjust the speaker settings.
Press the HOME button, Goto Settings > Audio Settings > Speaker Settings
See page 35 of the manual : HERE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
many thanks for your reply.i never knew about the menu you pointed out as there were no instructions like the ones you pointed out to me,eventhough the units were new.
thanks again
