Hi there, just want to know whether BDP-S4100 or BDP-S5100 supports RMVB (.rmvb, .rm, .rv) files?
Hi there
I can understand your confusion here. The Hong Kong site says its supported, whereas the UK site (and others) only has a brief run-down of supported files.
Unfortunately I cannot shed any light on this either. However I do have a suggestion - You could copy a few of the files that you want to play onto a USB drive, visit your local Sony Centre and test it on one of the models in the store. The sales staff usually dont mind (if you ask).
Hope that helps.
Don't think so - these are Real Media related extensions right?
Hi there
Hope that helps.
