- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Has anyone else had trouble following the recent upgrade where the S1100 blu-ray player doesn't run opera apps anymore? And when you try to open a SEN app, it says 400 bad request. I've been considering trying to re-upgrade with a cd using the UPDATA_M1R0138.ZIP I downloaded from the Sony website, but I'm afraid to brick the player. I haven't found enough technical support to guide me through the process.
Any help would be appreciated. I'm super frustrated because I really wanted to be able to use some of the apps.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Switched it on last night and got a message to say an update was available. Downloded it and bingo everything now working - Demand5, Opera App store and all the Apps are working as they should. Thanks!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are there any support staff from Sony reviewing these fora?
Is anyone else having trouble with the Opera Store? Or Sony Entertainment Network apps?
Help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You should be able to update the firmware from the player itself, which is a little simpler than the USB stick version. Maybe give that a spin first and see how that works..?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tried that, but when I did, it said, 'already updated' and doesn't do anything else.
Interestingly, after my initial post, it received an update through the network which i promptly installed, as you suggested and the problem seemed to go away. I could access the Opera Store with no problem. However... flash forward 2 days later and again it doesn't work. I'm not sure what the problem is. But I don't see an easy way of contacting Sony to fix it.
Any help?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you tried unplugging the router from the mains? this will force the Blu-ray player to reconnect. Could also try runnig a factory reset on the player as well..
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, but that didn't work. It still says, 'we are sorry but your device is not supported' when I try to open Opera TV store.
I tried both disconnecting the router at the mains and factory resetting the bluray player. Is there any way of forcing it to reinstall the recent upgrade?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm thinking of returning this blu-ray player. I'm still within the time limit. I'm going to get a Samsung. I can't believe what shoddy service I've gotten for this player. Sony used to be so good. 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Go to [Setup] then [Resetting] then [Initialise Personal Information] then go to [Video] or [Music] then [Update Video].
This should work for you aswell...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have a S490 and the store was working fine until today. I now get a screen that says "We are sorry but your device is not supported (err:495)." Also getting the 400 error in SEN.
I have the latest firmware, I have tried resetting the browser settings, Resetting the machine in set-up, and turning the machine of at the wall as previously suggested, but to no avail.
All other functions work OK. i.e. Netflix, LoveFilm, iplayer etc.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Can you look at your settings and ensure that Javascript is enabled?
Cheers.
