Usually a temporary IP issue, have you tried physically unplugging your modem for 30 seconds to power cycle it? This should then force the BDP to get a new IP address which should means it then checks ths Sony server for the local listing
Hmm - are you able to test it on another internet connection, a friend or relatives perhaps? For whatever reason its not getting the service list from the Sony server. Could also get your ISP to check/reset your connection then this might trigger it..
thanks
Thanks for the tip skl1983, I had the same problem and it saved me throwing the player out of the window
