Has anyone had any success with Google cast and SRS-X77? I have bluetooth, Airplay, and playing music over WiFi using the songpal app working ok. With Google cast all devices (PC, Android, iPhone) see the SRS-X77 and attempt to cast to it but no sound ever emerges. When casting from iPlayer Radio the link light turned blue which looked encourageing, but no sound. Anybody got any ideas?
Feedback from Sony was:
Thank you for contacting Sony support regarding a firmware update for your Sony SRS-X77.
In regards to your enquiry, please note that we are unable to confirm when will the next firmware update for your device be released. However, we recommend that you keep checking the support page of your product for further updates.
