After the latest FW update I cant use the streaming services Spotify and Chromecast. All other Chromecast and Spotify Connect devices on the network works like normal. (inc. other Sony devices..) Anyone that have a solution? At the moment I have connected a Chromecast Audio to the receiver, however that device is needed elsewhere ... 😐
Br
Hi pirayan, try a simple power reset (unplugging everything and disconnecting from the mains). Try restarting your router as well.
Thanks for your feedback however that have not solved my issue.
Do you see any error messages when you use the streaming services, or just a black screen?
It's a black screen showing a progress bar , connecting to internet content server (1/3)
Could you try to connect the amp to another network *smartphone hotspot for example?
I have 6 other Chromecast/Spotify devices including a Sony Tv that stream without any problems. I would assume that this device works just like the others ...
Hi Pirayan,
It is always better to test a different network as the amplifier works differently than the other devices. This could just function as a test. Let me know if this works out for you.
Regards,
Gladio
