just bought a sony srs-xb402m since I read that it was multiroom compatible with my sony str-dn1080
Both devices are connected to the sony music center, and direct connection works fine. But when I enter my receiver and press "group with other speakers" the sony srs-xb402m doesnt show up. The only custom thing I have done with it is to change the name of the speaker (from sony "srs-xb402m" to "Extra bass") - just mentioning it if that has something to do with it
It's European bought (Norway) - and both devices has the latest software
Brds
Hi Tertis,
Unfortunately the XB402M cannot be used in groups.
Please check this compatibility chart:
https://vssupport.sony.net/en_ww/device.html
