Does sony produce Cd players (decks). ?
Hi Alphadec,
We have a wide range of portable CD players and Boomboxes: http://bit.ly/2y10ZFp, as well as our MAP-S1 High-Resolution Audio CD Receiver: http://bit.ly/2ACCunJ. Please take a look at our site for the full range.
Thanks,
Owen
@Owen_G wrote:Hi Alphadec,
Thanks,
Owen
I own a STR3400ES! reciver and like to have a CD player (deck) 43cm wide in black. Thats what I am looking for.
Sony doesn't make CD player anymore. The only thing you can do (with a Sony porduct) nowdays and that will suit your AV receiver, is to buy their UHD player and use it as a CD transport .
Hi @alphadec,
I can highly recommend the Sony BDP-S6700 as a CD player.
It also plays DVD, Blu-Ray and 3D-Blu-Ray.
I hope the design is what you are looking for
- Nic
