lbt a190 fm radio aerial problem
rarmour
New
my fm radio just produces a hiss.  Ive checked the continuity of the loop aerial and its fine.  Any ideas?  Thanks
1 REPLY 1
profile.country.GB.title
jumpsuit
Expert
Hi @rarmour and welcome to the Community :slight_smile:
Has the radio worked previously in your location?
Aside from a  fault (as you probably know) hiss usually occurs
because the signal strength is insufficient.
