Hello, while watching a movie, I sometimes outsage the rear speakers for about a second and then run normally again. is very uncomfortable listening. you can't help some what about that? in the soundbar settings, the priority of the connection quality is set and the distance is 3m from the main soundbar. Thank you
Have you tried power cycling the soundbar and speakers (removing all cables and unplugging for a few minutes)?
didn't try but I'll try
Hi Swindour,
Let me know if this works out for you as well.
Regards,
Seif
in the end it helped to switch from automatic connection of rear speakers to manual and it's at least I think after the problem
