I recently bought this AV receiver second hand, however the remote (RM-AAP024) seems to be playing up. Is this the only remote that is compatible with this device?
Hi Montcord,
Welcome to the community.
I'm not too sure if it's the only remote that's compatible -I'll see if i can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi Montcord,
Welcome to our community!
There's a replacement remote for this AV receiver and its exact model is RM-AAP023 but since this receiver is already 10 years old (time flies!) you may not be able to find either of them. Anyway, here is their exact part number which should help you look them up:
RM-AAP024: A1512405A
RM-AAP023: A1512409A
Hope you'll find this helpful.
Regards,
Batee5
