Hi, I can't seem to pair any device to my HT-CT60BT sound bar via bluetooth. I've tried my iPhone 5, iPad and MacBook Pro. None of them pick up the sound bar and both are in bluetooth pairing mode. Any suggestions?
Hi there
When pairing, you have to be pretty close to the soundbar. Also press "Bluetooth" on the soundbars remote control.
See pages 16-20 of the manual : HERE
Also, at what point does it fail?
Hi there
To be honest, I have absolutely no idea why its not working
In the manual it states that the device must support A2DP. iPhone 5 does: http://support.apple.com/kb/ht3647
Unless another forum member has any other ideas - suggest contacting Sony Support : HERE
I have the same problem.
it used to work.
