I cannot find a replacement for the above, any ideas where I can get one or a suitable alternative?
Many thanks
If you Google for 'LIP8' or 'LIP-8' you will be inundated with hits for 'compatible' replacements.
I don't think you will find a genuine Sony replacement so you may have to pick one of the bunch and go for it.
Jessops are a reliable retailer but a little expensive: -
http://www.jessops.com/online.store/products/76333/show.html
There are several cheaper ones available if you are prepared to take a chance??
http://www.smartbright.co.uk/digital-camera-batteries/Sony/LIP-8.html
