Hello,
I would like to connect my PC to the soundbar via optical cable connection, so that any sound/music coming out of the PC is played through the soundbar. Is this possible to do with an optical cable, or only with an analog 3.5 cable?
Thanks in advance
Hi there
I can see why it wouldnt work to be honest. Just ensure that your PC is outputting audio via optical in the sound settings and ensure the soundbars input is set correctly (TV).
