- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Unsure on what error your referring to, because these are error messages (apparently) for your model:
However, its recommended a Factory Reset if things do not operate normally:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Unfortunately the error message appears as soon as switched on and none of the buttons respond. Thanks for your reply
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Check the diagram schematic on this model .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Do you find a solution at your problem? I have the same problem, and ccan't sove it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Unfortunately I haven't been able to solve it either
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I also have a FW-ERROR, on my CMT-BT80WB. I have tried to reset it as described here but it doesn't work. What to do? Thank you for your help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's nothing you can do, you have to send it in to Sony. Mine is under 5 years old, so I think they will pay it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem on a CMT60. FW error and unable to factory reset. The error appears as soon as it is powered. The unit is exactly 3 years old.
