This flashes constantly, otherwise the device appears dead. The manual says the solution is to go to a dealer. Any ideas about how much this is likely to cost and whether it's cost effective to fix?
Hi there
Unfortunately no one on this forum are authorised Sony repair agents and cannot tell you what is exactly wrong with it or the associated costs. You will need to seek a Sony Repair Centre local to you via: http://services.sony.co.uk/support/en/repair/asc
Hi there
