Hi
I currently have a DAV DZ260 home cinema system and I use the audio in plus 3.5mm jack to connect to a DAB tuner.
I am thinking of upgrading to the BDV N7100W home cinema system, does this have a suitable audio in socket or anything else that would connect to a DAB?
Regards
Ian
Hi there
As you might have guessed, the BDV-N7100W does not have a 3.5mm audio/headphone socket. However at the back of the unit, it does have 2 RCA Audio in jacks - highlighted in Red below:
See pages 16,23,24 and 30 of the manual : HERE
All you will need extra is a RCA to 3.5mm lead or converter lead. There are many on Amazon for only a few £. Such as :
www.amazon.co.uk/3-5mm-Stereo-Socket-Phono-Plugs/dp/B0009N1MV4/
or
www.amazon.co.uk/Cable-Tex-3-5mm-Phono-Stereo-Audio/dp/B0038K65MQ/
Hope that helps
Hi there
or
Hope that helps
Nice one, now I can buy with confidence.
Many thanks
Ian
