Hi. Was from a store called Richer sounds in November 2021 so not in warranty but I do not use an awful lot.
Hi again
Have you contacted Richer Sounds about this as they were the vendor?
They may try to redirect you to Sony but I believe the responsibility lies with them as they sold it to you.
I have the same problem!
Hi I will attempt to give them a ring to see what they suggest, it inthink they will just get me to contact sony direct. From what I have seen elsewhere this is the fault since a particular update.
I have a problem with my right ear bud, sudden battery drain. I lost 10% charge within 2 songs! and after half an hour it's dead. Bought in september 2021 for over £240 this is really bad. just been checking online and found this is a widespread problem since update late 2023.
Hey @deltur, that's true, it's a common issue. Have you tried resetting and initializing the headphones?
