Is it possible for me to transfer my taped videos to my lap top? I have a Sony CCD_218E, Hi8 camera.
If it is, exactly what do I need please?
Thank you
Hi Condover.
I assume you have a CCD-TRV218E camera?
If so, this is an analogue Hi8 camera and you will need a converter to change the A/V to the digital format needed by your PC.
Do you still have the original A/V connecting cable shown on Page 123 of your User Guide that you can download from here: -
http://pdf.crse.com/manuals/3079468141.pdf
It has a Yellow video plug and a black mono audio plug connected to a 3.5mm jack plug. You can use this to connect directly to a VCR Tape Recorder but you will need something like this to capture the output digitally on your computer. Prices range from £5 to £250 and some come with editing and DVD burning software.
Cheaper: -
Mid Range: -
Expensive: -
You pays your money ........................... The more expensive ones also come with better software but you can use third-party software with a cheaper device.
Just a hint. When transferring from your camera, choose 'EDIT' and connect the mono audio jack to the white input.
Good Luck!
Hi Condover.
Cheaper: -
Mid Range: -
Expensive: -
Good Luck!
