Just bought a sound bar and telly Sony delivered and set it up. But bar works until 12 midday then goes into standbye. How do I stop that?
Hey @Alan09
Can you make sure that the auto Standby option isn't enabled? https://helpguide.sony.net/ht/2079/v1/en/contents/TP1000843228.html?search=Standby
Also, could you confirm the model of your TV?
TV is 48 inch XR48A90KU how do you cancel auto standby with remote control?
You can follow this: [Settings] - [System Settings] - [Auto Standby]
