KD-43XG8196 - Sony Channel Editor Problem 1.20 V
Does not work on Windows 10 PCs
Can anyone help me
If you want, and you trust ... I've realized a Portable version of Sony Channel Editor:
https://mega.nz/#!btdSFA4J!nZigkagp4pf8GjbtyMe8TdAlyEYlHCxH879EsBAEddY
Please, remove the Sony Logo on your Avatar.. Thank's.
quello che mi hai inviato non funziona
It works for me, have you installed Java on your PC?
I've also version 1.1 if you want to try...
No....🤔 devo installare java ...
Grazie per l'aiuto e il tempo 🙏
Actually it would all be in the Portable version but the Java installation could resolve.
The Avatar... 🤔 👎
