I have recently purchased a Sony HT-RT3 5.1 for a home cinema and I wanted to Bluetooth it with the projector. The two connected without any issue however I cannot get the voices synced up, there is a delay which is noticeable and annoying.
I did did think about moving the subwoofer to the back of the room and closer to the projector but the cable from the front speaker is not long enough. The headphones work perfectly when sitting directly underneath the projector so I’m hoping moving the subwoofer closer will have the same effect
If anyone has the answers to my issue I would be very grateful
thanks
Hi Dale,
Welcome to the community.
We will look into this and get back to you when we find out more.
Maybe some of our community members will be able to advise you until then.
Best wishes,
Ed
Hi Dale1603,
Does the same thing happen if you disconnect the Bluetooth and connect the soundbar to the projector via cable?
Cheers,
The_Black_Rose
